Need advice on a low end system build. please give me a hand
Johnbear007
I'm used to working with high end parts, but I need to do an upgrade for a friend for under 200$ (as FAR under as possible)
Need a cpu/mobo/ram 256 megs max. THis machine is for internet, and possible SUPER LIGHT gaming.
Mobo = Biostar nforce 2 IGP $62 @ mwave
Ram = 2x 128mb $40 😕 @ staples, CC, omax, OD AR deals
CPU = XP 2400 $68 @ mwave
HSF = $5 @ SVC
total $175
even cheaper
substitute xp2400 for xp1500 subtract $32
substitute nfroce 2 for km400 subtract $11
total $132
even cheaper
Duron 1.6 with ECS $50 @ Fry's
256DDR = $30
HSF = $5
Video = $40
total $125
Thanks, im not very close to a frys (at all hehe)
Also, I dont need to do a dual channel setup. I dont want them to have to mess with rebates, it may be too hard for them
I really appreciate the response though. ill keep looking for mobos.
Maybe just an ECS k7s5a lol
I think they are on a 500 mhz celeron so even a 1500+ would be a HUGE upgrade.
No fry's? Then it is worth getting a KM400 for $10 more over the $30 K75SA, due to lack of video on the K75SA.
HSF $2
Rest of it $113
total $115 + shipping both svc and mwave have good shipping prices and reseller ratings.
Originally posted by: Salvador
Friends don't build friends systems with ECS mobo's. 😉
Sal
hehe..
the K7S5A was a fine mobo, it got a bad rap because alot of noobies used it to build and complainned when they couldnt get it working.
I have build systems for friends with it many times. However recently ive been only working with high end stuff so I have paid attention to the budget parts.
HSF $2
Rest of it $113
Thanks, I am familiar with both places. This is probably the setup I will go with.
Epox nForce2 8RDA3+ - Retail $89.00
AMD Athlon XP 2500+ - Retail $91.00
Crucial 184 Pin 256MB DDR PC-2700 - OEM $42.00
Total $222.00 all from Newegg, $22 over budget but well worth the extra $.
Wait for another paycheck and then pull the trigger.
rb56
rb56
These people dont need anything near that kind of power. It holds no value for them, and isnt worth the extra money just for web browsing. That is more of a gaming budget system, which they doent need.
rb56
Just because they only use it for internet doesn't mean you shouldn't make the most out of their $200. If you're not willing to do that, then pick out a dusty/refurbished/ancient P1/2 system from your local Microcenter/generic computer shop for the same price.
Mobo = Biostar or Shuttle nForce2 ~50 @Newegg
256MB PNY FAR or ~$10-->$20
XP2500 = $60-->$70 from Trading Post or Ars Agora
Case Any $40
MB MN31N SHTL $65
CPU AMD|2500/ Retail $90.00
DDRAM 256MB PC-2700 APACER INFIN% $39
HD 40GB|ANY $55
=$279
Now where's the rest? floopy $8, CD $20, KB&MS $30 etc....Don't buy those mini computers..not worth unless you lan..
rb56
Wow talk about hostile. That's simply just not a wise investment for them. They are relativley poor so the sifference between 220 and 120$ is HUGE to them. Deal with the fact taht there are people out there that CANT afford much. There is a world of difference between one of the old systems you mentioned, and something I could put to gether for well under 200. You are pushing your own misguided agends for some reason, and it isnt shared here.
Biostar M7VIG Pro with IGP - $55 shipped
Athlon XP 2100+ retail - $70
Crucial PC2100 DDR (1x256MB) - $38
Total=$163
This is very similar to K7S5A board, but with IGP. it will handle either DDR or SDRAM.
Is IGP necessary? Or are they OK with current VGA board?
If IGP not necessary, save a couple more bux and go with K7S5A...it's a fine board which is meant for EXACTLY this type of application. Good luck.
