coffeejunkee
jchu14, yes the $220 is also from microcenter. I guess then the 4 vs 6gb ram cost is moot because I can run 4 on the 1366. Good point about efficiency. Anyone know how efficiency compares when both chips are OC to 4ish?
If you plan on overclocking to 4GHz and staying there you might as well get an i5 750 since you'll probably have to turn off hyperthreading and turbo for sure. I guess the i7 860 need a little less voltage though.
I'm curious about efficiency figures myself as well.
The P55A-G55 is a good mobo for Socket 1156.
It's cheap, but is it really good? Seems a bit low on phases/cooling for 4GHz overclocking to me. I would go with the GA-P55-USB3 or higher.
