1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Mix between gaming and photo/video editing.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
Around $800
3. What country YOU will be buying YOUR parts from.
USA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
No preference
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
HDDs, DVDR, and maybe the monitor. My budget above didnt include a monitor, but I can upgrade this later.
6. IF YOU have searched and/or read similar threads.
Yes
7. IF YOU plan on overclocking or run the system at default speeds.
Default to start with will probably OC slightly.
8. What resolution YOU plan on gaming with.
1920x1080
9. WHEN do you plan to build it?
Now
Here are the things I already purchased:
CPU I just bought the i7-930 from Microcenter $200
GPU Galaxy GTX 470 from TigerDirect for $230
Case NZXT Hades from Newegg $50
Subtotal: $480
I need a Mobo, PSU, and RAM.
Id like to get a SSD, but doubt Ill have room left in the budget. Since my GPU will run hot, Id like to find an energy efficient PSU to try to offset the extra heat. I wouldnt mind a nice combo deal for a large 1TB HDD like this one (http://www.newegg.com/Product/ComboD...D=3332167&SID=) but dont know anything about the quality of the two. I suppose 80% efficiency for the PSU is good?
Thanks!
Around $800
USA
No preference
Yes
1920x1080
Now
Subtotal: $480
Thanks!
