Originally posted by: brentw
Originally posted by: Operandi
For any drive to "near-silent" it will have to be soft mounted. As far as the drives themselves all of them are near silent idle. I have modern Maxtor, WD, and Seagate drives in my system all soft mounted and personally I think the WD and Maxtor have the softest seeks.
What do you mean by soft mounted? Like with rubber grommets?
Right, basically the idea is to physically isolate the drive from the case. One way is to use grommets like these E-A-R mounts, which is what I'm currently using in my Lian-Li after some modifications to the HD cage.
Did you notice a major difference by using those in your lian-li case? My PC is near-silent except for the high-pitched whine of my hdd.
Not to jack the thread too badly, but I was looking at getting some mounts/grommets like these for the card cage in my Lian-Li PC60, and I was worried about fit... what kind of 'modifications' did you need to do? Or were you trying to isolate the whole card cage?
No problem, I don't mind going off on tangents
I want to keep the drive size at 120gb because of the Mac's limit. There are software workarounds, but I'd rather just get an external Firewire drive for storage. Hmm, Seagate or Samsung. Do the quiet Samsungs come in 120gb? I'm searching around Newegg and google right now without much luck...
Yes, they come in 120GB, but Newegg doesn't have them (they seem to be very lacking in Samsung drives all of a sudden). Model number is SP1213N for the P80 120GB PATA drive with 8MB cache. Searching on that seems to turn up a number of stores. ZZF has them, but they're OOS right now. ExcaliberPC seems to have them in stock.
The SP1614N is the 160GB version; shouldn't be any problems with just using 120GB of a 160GB drive (except that you're wasting 40GB of space...).
Yeah, I'd rather just get the 120gb. I'm glad they have a 120gb model; I appreciate the info, Matthias99. It's now on my list to get when I can find it in stock!![]()
Did you consider the laptop drive option?
Yeah, but I can get a drop-in solution with the Samsung. I'd have to get a 2.5" adapter cable plus enclosure adapter to fit it in. It's a good idea, but the Samsung wins in this case. I appreciate the input, however - thanks!
Well you would need the adapter cable but as far as mounting goes what most do is suspend the drive like in the Antec P150 with some bungee cord or similar. Since the drive is so much small there is plenty of room, head over to the SPCR forums if want to check it out further.
Hmm...the other issue is cost. Oh, and speed. A 60gb 7200rpm Hitachi is still ~$150, while I can get the Samsung for $85 AND double the capacity for probably similar noise levels, if not less. I'll be doing video editing and stuff with this machine and I definately don't want to go with a 4200 or 5400rpm hard drive. The bungee thing sound cool though![]()
Well you're dealing with a machine that is about 4 years old. I think at this point laptop drives are probably fast enough to not be the bottle neck in a machine like that. You have to keep in mind areal density is just as important as drive RPM. I have a 2.5 Samsung in an external enclosure hooked up via Firewire and it seems pretty quick, maybe somebody else has some more info here. What I can say for certain however is the 2.5 drive will be much much quieter then any desktop drive you'll ever find. Really the only downside is price which you already noticed.
Originally posted by: cubby1223
Seagate has seemingly had many problems with their sata drives. There were some issues in some threads here recently about the 300gb 7800.8's, and Newegg product reviews have had more bad reviews than other brands, and even I had gotten a funky 160gb sata Seagate a couple months ago from Newegg. And I was looking at a Dell machine last week that had a 160gb sata Seagate, and it was the dang loudest drive I've heard since the days when 20gb was max!
Samsung has been my favorite in hard drives for a quite a while, even though I do have a 200gb pata Seagate in my own system ('cause back when I bought it, Samsung's largest drive was 160gb).
Originally posted by: chilled
The seagates are very quiet. The samsung drives are very, very quiet.
I managed to snag a 120gb Samsung SP1213N (P80 series) hard drive here for only $78:
http://www.komusa.com/sasppse12at7.html
Thanks for all the input! My Mac gets it's first mod in a week![]()
