I am currently using a 3.2 P4 with 1GB of RAM adn a ti4200.
I have a 2005fpw on the way which has a native resolution of something like 1600x1080 or clsoe to that.
Questions:
1) If I wish to play Half life 2(Counterstrike) will I be able to play on my ti4200?
2) If yes to #1 will I be able to play it at native resolution of 2005fpw?
3) Does Half life 2 support native resolution of 2005fpw, meaning is it a choice in video settings of Half life 2?
4) If I need to upgrade I want to keep it at around $200. WHich card would you fine people recommend?
5) Finally, the card you are recommending will that cars support native resolution of 2005fpw in Half life 2?
Thanks in advance.
Questions:
Thanks in advance.
