Need a laser printer....
Originally posted by: Entity
I'm considering this now too -- my HP 4M+ is finally starting to screw up regularly (with feeding paper). Budget $150 or under, preferrably. Printing ~2000pages/year. Advice?
Rob
y don't u just order a paper feed roller kit from hp's site?.....lot cheaper than $150 bux and it'll fix ur feed problem
Originally posted by: sathyan
on a different, but related note, print servers
Is this Edimax print server any good?
http://www.newegg.com/app/viewProduct.asp?submit=list&catalog=387&DEPA=1&order=price&sort=asc
I want to use WiFi on a notebook to connect to the printer via my wireless router without needing my desktop on.
Notebook <Wifi> Router <ethernet> printer server <lpt> printer
Mine works, most of the time. I think the problem is that it attaches directly to the centronics port on the printer. On the Lexmark e210 that means the led's are face down. I have had some connectivity issues with it which I think relate to the pressure it puts on the centronics port.
Rob
Didn't know they had them, or that it'd solve the problem.
Rob
will definitely solve the problem......and they definitely have them....just take a look at this link and you will find what you need....believe me, we have hp laserjet 4's in our office w/close to 500,000 prints on them......all it needs is a printer maintenance kit w/some feed rollers
Linky
Originally posted by: John
I have (2) HP LaserJet 6L's that I picked up off eBay a year ago in mint condition for 50ea + 25ea shipping FedEx Ground. I also bought the 8MB memory upgrade for 20ea. The 6L's are some of the best laser printer ever produced and are still sought after today. If you apply the multiple paper feed fix you'll be set for years to come. Toners are easy to come by and last a long time.
I happen to have several spare original HP paper feed fix kits for $5.00 shipped USPS Priority if anyone would like some.
Get your free 5L/6L service manuals here
odd, i feel like getting rid of mine =P
anyway, the 1440 is a cheap printer, and it works according to users. i got myself a $400 samsung 2150 which can do duplex printing and has a paper tray. it replaced my slower and older 6Lse.
Linky
$40 for a kit. 🙁 I'm going to pick up a used LaserJet for only $60, so I'll stick with that.
Rob
keep in mind...."used" is a loose term....it may come to you in need of the same type kit that yours is in need of....what if you get it, open it up, install it, and then it is jamming just like yours?......then you're back to square one......you need to find out just how "used" the printer is....i.e. how many prints does it have on it.....printers are like cars, buying a used one can be very dangerous if you don't know the mileage
The one I was looking at already had the paper roller kit installed (and came with an extra toner), but thanks for the advice. My current printer is about ~7-8 years old, with lord knows how many prints on it. 😀
Rob
