- Mar 8, 2003
- 38,416
- 4
- 0
ok, im tired of my tornado fans that are 55db even tho they move about 85cfm. i need something quite that can move a good amount of air that can keep my athlon running under 60C. the tornados keep it at 62 with the speed turned down to reduce noise, but i need somethign quite. what fan should i get for my SLK800? also, will 120mm work on it?
also, is the compound that comes with the thermalright good enough or will i be better off going ahead and ordering some artic silver?
