Hey everybody, just thought I'd give you guys a little update on how the FireWire is going.
As you may know from reading I bought two ADS Pyro WebCams with the FireWire interface to setup between myself and my girlfriend.
The cams were shipped as expected, although slightly underpackaged in the big box.  It was ok though since their original backing had so much open space already, they weren't in much danger of being crushed.
Installation went very smoothly, stick the FireWire card in, install the drivers for the card.  Then install the drivers for the cam, THEN plug in the cam.  No problems whatsoever.
Next, well I haven't tried out much of the software, I pretty much went straight to it's default Pyro WebCam software and NetMeeting.  The picture was very clear locally, VERY clear, although slightly grainy in large size.  It could learn from the 3Com's low light processing though, you need an average bit of light I suppose to get a good picture.
Next, local streaming was smooth, at the advertised 30FPS, you can see the very minimal bit of catchup that you'd expect at 30FPS.  You have many options of resolution, unfortunately, so far I've only found that the default local webcam software supports the full 640x480 resolution.
NetMeeting for some reason is ok for one person, but the other party is fairly choppy.  AND it bumps it down to 320x240.  Streaming over the net was ok, but could have been better.
I went with another option that a kind individual on this forum pointed me to, VDOPhone.  I'm pretty sure that it's been discontinued, but for a 3 year old product it works very well.  The internet PC-to-PC connection is very smooth with the cams, clear, although you can't really read text on a paper (just so you don't think it's THAT clear).  However this is most likely because it is also limited to a 320x240 resolution.  (If you know of a program that supports higher I'd REALLY like to know!!)
Voice communication at the same time is also decent, there is obviously the lag time, but it syncs pretty well with the video.  A note with VDOPhone though, after 30 minutes the audio really really degraded for me.  A quick session restart fixes it every time though.
All in all I'm happy with my purchase, if you have any questions about it feel free to ask!
