My guess would be you have a regulator or power supply problem. When the system is completely powered off, with the power strips, all the capacitors begin to discharge, they take a while. After they completely discharge, the initial load on the pwer supply is higher and could cause this problem. ATX systems don't require that you power off at the power strip. Try leaving the power strip on and see what happens.
