Originally posted by: MODEL3
Originally posted by: BenSkywalker
Multi comes from multus, which means many.
Core is a bit more tricky as depending on the useage the word has several different origins, corpus being the oldest which deals with the heart or center.
I agree that this is one valid definition of the term,
I suppose you don't imply that i said something different from this.
(For the Greek term "
core" ,the greek word is complex from other 2 words (like the latin term is also) that can show more clearly than latin the origin of the notion that it represents, Greek is way older than the Latin Language, but anyway this is not point here)
You are very right indeed, my closest friend has a degree in linguistics and socio linguistics, nights spent drinking I have been served up rather lengthy and in depth analysis of exactly that topic. In this particular case however, the word hasn't evolved.
Thanks.
Then for this point we agree.
I have not said that what you claim is multi core is not, what I have repeatedly stated is that you are excluding numerous offerings that are multi core improperly.
Sorry then I misunderstood, I had the feeling that this is what you meant.
So if you just meant that I excluded some offerings that click with the "
heterogeneous core design" then you are correct.
I said it myself in my previous reply also.
While it appears most of your research was suspect at best, particularly relating to how the word was added to English,
I never implied something about how the word was added to English and I have done no research about it, like I care, I just implied that the meaning of a word can change in time becauce of the way people use this word in each particular era and that maybe the people that defined the term in this era changed the original notion. Like I said in my previous reply this didn't happen pointing to the Wikipedia staff.
at least you came across the Wiki entry that can help you gain a bit of insight. Sadly, I linked that article several posts ago which if you would have clicked it in the first place, we could have avoided this sidebar
Yes I should, It took me more time answering to you than to check in Wikipedia what is the current notion in the Tech. World for the term "
multi core".
