Hoping you can assist -
Recently I put together an AMD XP 3200+ (biostarm7ncd ultra) system (I say recently 'cause dirt etc are not yet a factor...)
I have had a tremendous amount of stability issues and am currently thinking that heat may be an issue.
The Nvidia system utility reports general web browsing temps at 43-46 degrees- however anything taxing (3d games, burning cd's, itunes etc) and the temps quickly shoots up to 55-60+ and the PC freezes. It has also froze at lower temps, however this is much less likely.
I also notice that mbm5 reports the temps as 43 / and 50 when the Nvidia util reports 43.. Nv lables this as cpu die temp, whil mbm5 reports 43 as case and 50 as die...
How likely is it that the stability issues are a result of heat? I have reformatted / re-installed windows, run clean boots, read the bios settings many many times.... about ready to throw the thing out the window
I purchased the system from mwave.com... the cpu / heatsink came pre attached... so I can't comment on the TIM...
Any comments appreciated... Brad
