NBA Fans: How can the block of a dunk NOT be a goal tend?
PlatinumGold
23,168
particularly the block of Duncans Dunk by Stoudemire. Duncan was CLEARLY coming down with the ball and the Stoudemire's hand was CLEARLY in the cylinder when he blocked it.
how was that NOT a Goal Tend?
UncleWai
5,701
68
Duncan's still holding the ball, duh, like the broadcaster said, that's a MAN block.
Plasdom
642
err...because it was still in Duncan's hand? Easy. Just because you are dunking does not mean you should have free reign
iversonyin
3,303
that was a clear block....0wned!!
and every dunk is on its way down....so if it goes by your rule... you can never block a dunk
PlatinumGold
23,168
ya, that kind of works but not entirely.
to be honest, all dunks should be Goal Tends also, as the offensive player CLEARLY is touching the ball while the ball is in the cylinder.
iversonyin
3,303
the ball wasnt in the cyclinder this time.... and Stoudmire's hand didnt come up from the rim
http://www.nba.com/analysis/rules_11.html?nav=ArticleList
official rule, which one Stoudmire violated?
SludgeFactory
2,969
His hand started out in front of the rim, he made contact with the ball, and then it was driven into the cylinder as Duncan continued to force the ball down. No goaltend.
Amazing wrist strength to stop Duncan like that.
zainali
1,687
amare got pissed at the end of the game after manu grabbed him ( and he knocked manu down).
his block/rebound at the end of the game and defense on duncan won them the game.
amol
11,680
If it's still in the hand, the ball is not in the act of going from the shooter to the basket
boyRacer
18,569
that looked more like a flop from Ginobili
Miramonti
28,653
100
I assume he has to let go of the ball for it to be goaltending. Remarkable block, most people would have gotten a broken wrist.
Vic
50,422
14,337
The ball is still in the shooter's hand is why. A shot has not actually occurred until the shooter releases the ball.
TWills
905
<<<still waiting for NBA "no-travel" reference...
EagleKeeper
Discussion Club Moderator<br>Elite Member
Staff member
Oct 30, 2000
42,589
If the shooter has control of the ball, it can not be considered a goal block.
