NATO vs. Russia
videogames101
6,783
27
Originally posted by: videogames101
Originally posted by: TehMac
The Mig29 (Mig35 now, basically a '29 with upgraded Avionics), Su-27s, and Su-37s are all really fine aircraft.
any vs. F-22 = fucking raped russian
indeed
and the F-35 will rape and pillage just about anything it needs too.
You forgot to mention the US Marines.
... because I don't bash the U.S. Military... :confused:
I don't understand, the F-35 and and F-22 can rape and pillage and it's a good thing...why the US Air Force always get away with stuffs. They have the most expensive toys and they probably killed more people than Cecil DeMille.
If I had access to the toys they have, the world would be destroyed 10 times over. People underestimate how badly our airforce could dominate a war in which they actually have targets.(unlike the one in iraq)
destrekor
28,799
359
indeed
I have no idea what you are trying to say. Wanna try again?
And because of that, I think I confused what you were trying to say about the U.S. Marines. Nevermind that comment.
So the F-22 is USAF. The F-35 will be in the arsenal of the USAF, US Navy, and USMC. No STOVL capability for USAF variant.
Regardless... what service gets things done is not important, all will have their purpose in a full-scale war, and will be very important. If the USAF ends up zapping more birds out of the sky than the USMC, does it matter? Or if the USMC happens to accomplish that task, does it matter as long as it happened?
Ichigo
2,158
The Korean War ended in a stalemate, by many counts. I don't see the "China got pounded into pulps".
LegendKiller
18,256
68
86
The difference in force effectiveness between now and Korea is huge.
mrSHEiK124
11,488
Even F-35s could rape those MiGs; ever play Battlefield 2 :p
fallenangel99
1,721
Easy.. whatever side has the better air/naval forces.. and that would be NATO/US.. Ground forces are not the same as they used to me. If Ground forces are included, then still NATO (with heavy casualties of course!)
destrekor
28,799
359
always need ground forces to capture territory, unless it's the open seas. Territory is the currency of war.
soydios
2,708
what Iraq and Afghanistan have shown us is that the USA kicks arse at full-scale war. it's occupations that we're not so good at it. it's a simple question of manpower: each soldier is an incredible offensive weapon with all the tech we have, hence we win the full-scale war; but occupation requires a soldier on every corner, no matter how much tech they have.
TehMac
9,976
indeed
This argument has been beaten to death, I'm just saying...the Su-27 and Su-37 especially are impressive pieces of machinery.
videogames101
6,783
27
I couldn't have said it better.
TehMac
9,976
Vietnam showed that without a counter insurgency strategy, you're just cutting down your own men. Iraq has showed that America is not wanting to fight WW2 all over again, but minimize the conflict and use a strategy.
destrekor
28,799
359
you can have a lot of soldiers and a strategy and succeed. You can not have a strategy and some soldiers. Guess what, right now we are definitely at the 'some soldiers' level. There are nowhere near enough troops to get this thing done in a reasonable amount of time, if at all. The troop surge has been largely successful and has even forced the discovery of recent documents describing a growingly frustrated al Qaeda in Iraq with the increased security due to the troop surge being the cause of frustration. Throw more, and you'll find them even more frustrated. When they get frustrated, they screw up, they don't cover tracks, they try and use extreme force and in the process locations are discovered. Condense a bunch of them and they also run out of places to go. Honestly, we need to get NATO to support a general mass sweep of troops as they slowly move in a full 360 of the entire Middle East. It will require a hell of a lot of troops and a lot of recon sorties to maybe fill in areas of assumed least likely populated areas where the main elements won't go, or spread out so in small pockets they would be extremely vulnerable.. so mass numbers are important. Expensive. But extremely effective. Start from neighboring nations, at their furthest borders. Get the UN to help coerce the governments of those neighboring nations to cooperate. They continue to sweep in, and begin to form large elements as they move in. Eventually relieve a certain number to create alternating forward and rear elements. Get any possible threats confined in a small region. Do what you want from here. Maybe even send in units to evacuate certain interior locations prior (and briefly contain all and search and whatnot to determine if any are threats themselves), and possibly bomb an interior region once all threats have retreated into one common location? Safe houses are obviously going to be within these confines from the start, so all threats in the region will be forced into the interior, or killed on the spot.
Requires mass numbers, numbers the US alone can not afford to send in as one attacking wave as that would likely require all active and reserve servicemen. So UN support is necessary. But a highly effective, if possibly dangerous and considered a reckless move...
This occupation attempt is going to take forever to fully succeed, if that is indeed possible. More troops sent over will definitely help, and throwing a lot of units will be more effective at this stage, specially with a sound strategy. Follow the current strategy and use more troops and we're certain to make forward progress.
0roo0roo
64,795
84
russia is losing population now i think
no more zerg rush for them
not so much.
ww2 style we'd make sure they felt like they lost.
you know, bomb your cities into ruin, destroy everything basically until you give up.
right now its different, they still have fight left in them because our invasions are much less costly. ww2 enemies fought risking total destruction. current enemies don't really, they just hope you'll leave. ww2 they knew we'd leave when they were a smoking hole in the ground.
destrekor
28,799
359
Originally posted by: manowar821
ITT: Mindless nationalism and irrational fear of communism, alive and well.
this goes so much further beyond mindless nationalism and a fear of communism. Nobody can deny the fact that Russians love Putin, and he is good for them in some crazy way. However, we fear Putin may be a brutal man, has a questionable past, and won't stop at making threats. Nobody really fears communism, people fear the ruthless dictators that are almost always associated with the style of government.
And rooting for certain countries, namely your own, to win in a war and hype them as the best ever... that's mindless nationalism? That's called natural reactions to the question, especially when in the past it's been true and a lot of world thinks is true as well.
Probably tied to natural preservation... the idea of keeping yourself alive. Well I think the mind naturally fears losing a large war for fear of what the consequences will be at the end of the line, at the individual level. It's generally a depressing image.
Gibsons
12,530
35
I think it depends on how dedicated the Chinese are. Dunno why they'd want to get involved in helping the russkies or really care much about kosovoa at all. They don't like Russia very much and as someone else pointed out, they probably would like to get some Siberian natural resources. With no Chinese support, I think NATO wins, but historically everyone seems to underestimate the bear and pay for it in the end.
Exterous
20,612
3,834
It ended in a stalemate because thats what the UN wanted, not on the actions of the Chinese. In May of 1951 the UN decided not to advance north of the Kansas Line and into North Korea. The remaining 2 years of war were fought this way
0roo0roo
64,795
84
well not really, massive population is actually a disadvantage at times.
if you can't immediately feed them into the meat grinder of war you have to feed and care for the massive population.
never mind moving that many troops around a big area is very very difficult. its not like ur gonna have ur troops pillage your way across your own country to survive.
Pocatello
9,754
Why would the Chinese fight us? We borrow their money, buy their products, and we pay interest right on time. We're the goose which laid the golden egg.
thehstrybean
5,727
So is the F22 Raptor and the plethora of stealth bombers the US has...
But with China in the mix, R+C would win. China has MANPOWER. Wars of attrition are won by the country with the manpower and will to continue. Just look at Vietnam...
jjones
15,424
Who the hell is talking about invasion and occupation? I thought we were talking about war. Given the naval and air assets, Russia and China wouldn't stand a chance against NATO. NATO would completely destroy their militaries and infrastructure and then go home. Russia and China would spend the next several decades finding their way back out of the stone age.
K1052
53,728
48,385
At this point its not even a question. Russia cannot adequately defend itself against the combined NATO forces. It certainly wouldn't be any cakewalk but they'd get beat pretty badly.
As for China all you have to do is hit the power and transportation infrastructure hard and they'll go down (you've seen the chaos just a snowstorm caused). Probably take out what there is of their navy to prevent it from causing any trouble.
