Drafting (aerodynamics)
Open-wheel racing
In single seater,
open wheel racing series such as
Formula One and the
IndyCar Series a technique known as
slipstreaming is used. Along a long straight a car following close behind another uses the slipstream created by the lead car to close the gap between them, hoping to be able to overtake the leader under braking for the next corner, or if he has a straightline speed advantage, to pass on the straight. However it is very difficult for cars to follow each other close together in fast corners as the "dirty" (
turbulent) air that comes off the lead car unbalances the trailing car as its aerodynamic devices provide less grip. However, on the straight this effect is much less of a detriment due to the lower levels of grip required.
Stock car racing
NASCAR cars drafting during practice for the
2004 Daytona 500 at Daytona International Speedway
On the faster speedways and superspeedways used by
NASCAR,
ARCA, and at one time the
IROC series, two or more vehicles can race faster when lined up front-to-rear than a single car can race alone.
The low-pressure wake behind a group's leading car reduces the aerodynamic resistance on the front of the trailing car allowing the second car to pull closer. As the second car nears the first it pushes high-pressure air forward so less fast-moving air hits the lead car's spoiler. The result is less drag for both cars, allowing faster speeds.[2]
Handling in corners is affected by balance changes caused by the draft: the leading car has normal front downforce but less rear downforce. The trailing car has less front downforce but normal rear downforce. A car with drafting partners both ahead and behind will lose downforce at both ends.
[2]
Similar to the "Belgian tourniquet" in cycling, the "
slingshot pass" is the most dramatic and widely noted maneuver associated with drafting.
A trailing car (perhaps pushed by a line of drafting cars) uses the lead car's wake to pull up with maximum momentum at the end of a straightaway, enters a turn high, and turns down across the lead car's wake. The combination of running downhill and running across the zone of lowest aerodynamic drag allows the trailing car to carry extra speed and pass on the inside of the leader.[2]
Drafting was discovered by stock car racers in the 1960
Daytona 500, when
Junior Johnson found that he could use drafting as a strategy that helped him overcome the fact that his Chevrolet could not keep up with other cars, allowing him to win the race.
[3] Like Johnson, other drivers found they picked up speed running closely behind other cars; and as they experimented they found that a line of cars could sustain higher speeds and/or use less gas (resulting in fewer pit-stops) than a single car running by itself.
[2]
http://onebadwheel.com/nascar-101/aerodynamics-and-drafting-in-nascar/
http://www.troubleinturntwo.com/nascar-101/aerodynamics-and-drafting
