voodoo7817
I wish I had it too! If my order is cancelled (not anticipating it, but it's possible), I'm not quite sure what I would do.
The top chart on this page from Anandtech's review of the 415+ compares the HD Video playback performance of the 415+ and the TS-451: http://www.anandtech.com/show/8659/synology-ds415-review-dsm-on-intel-rangeley/3. The 415+ looks to have a slight edge on the 451, but it's really close and in real world performance I think the devices will stream very similarly. Unfortunately, I couldn't find a review that explicitly compares the transcoding abilities of the two machines.
Edited to add: FWIW, I found this quote in the conclusion of that 415+ review: "Pretty much the only downside from a home consumer perspective is the absence of a hardware transcoding engine for media-centric applications. Though many multimedia apps can be installed on the DS415+, media enthusiasts are advised to go for the Synology DS415play or QNAP TS-x51 if power-efficient media serving is a primary use-case." They don't elaborate as to the reason why, but one might imagine it's because they are better at transcoding. But I haven't been able to track down any explicit clear evidence of that.
My guess is that while each machine has small but real pros and cons, either machine is a good option for our needs (or is woefully inadequate), which is why it's a hard choice. I was able to use price as another factor, as the deal I got on the TS-451 was really good. Unfortunately, that deal isn't available which makes the decision a little harder. At the current ~$100 difference in price ($500 vs $600), the 415+ might be the better option.
