n00b Home Repair/Handyman thread?
Originally posted by: AllGoodNamesAreTaken
Hmmm, I'm not sure if toothpicks or golf tees ( mentioned by another poster ) will help me in this case. The hole is at least 4 screw diameters high and 2 screw diameters wide. It looks to me as if the installer tried to place the screw in 3 locations before finally securing it at an upward angle. I don't even own a drill 😱, which is why I was looking for a "space age" solution.
You should buy a cheap cordless drill. ~$30-$50 will get you a decent one. It's amazingly useful not just for drilling, but also as a screwdriver. I found this site handy, but it does recommend a corded drill.
Originally posted by: mobobuff
Quick MS-PAINT job
That's either a smiley face or male genitals. Or did I fail the Rorschach? 😛
If you're trying to get a threaded aerator off, you'd have to twist clockwise instead of counter-clockwise like normal, because you're behind the thread instead of in front of it (does that make sense?). Locking pliers and a cloth or a strap wrench would do well.
Quick MS-PAINT job
OK, I'm an idiot. 😀 I was turning the damn thing the wrong way, it came off fairly easily once I figured out wtf I was doing.
Quick MS-PAINT job
Good, but please explain why you think a leaky faucet can be caused by the aerator.
Originally posted by: Mermaidman
"Will it be disastrous if I use a small circular saw (5.5") to cut down a small tree ~3" diameter?"
q]
---home depot rental chainsaw, safest, not so scary
"Cold air is blowing into the house from the flue-less fireplace. How do I stop it?"[/
---chimney repair man, again.. safest.
if this was about like.. replacing a door.. window.. etc sure do it yourself. those are a couple of the things ive always been ehhhh about.
Quick MS-PAINT job
thats going to be a bad seal
Quick MS-PAINT job
Good point. But replacing/cleaning your aerator isn't a bad idea, just not a solution to a leak. I'm glad my drawing helped you out, though 🙂.
Quick MS-PAINT job
[/quote]
Haha, I see what you mean. It is funny, now that I look at it again. 😱
n00bs post your questions! Experts post your answers.
Me first:
I think your going to find that you have to pull that gas-log fireplace out to determine the cause. Could be that there is a loose connection of the exhaust vent or somewhere behind the unit is some kind of uninsulated area. You might need some type of fire resistant insulation though.
Hopefully someone can help me out.
A screw holding a kitchen cabinet door hinge to the cabinet frame came out. There is a gaping hole where it used to be, so I cannot screw it back in. I purchased some Minwax wood filler that claimed to allow driving screws/nails. It failed miserably, turning to dust when I drove the screw back in.
Is there a better product? I know the correct technique is to glue a wooden dowel in place, cut it off, and drive the screw into the dowel, but that is beyond my skillset.
Cheers.
Like theknight571 said, glue a piece of wood in there. Or, swap out that wood scew with a machine screw and put a nut inside.
Or, get some JBWeld if the repair isn't going to be seen. It'll hold a screw.
Quick MS-PAINT job
Did you somehow miss the part about me being an idiot? 😀 It's been a LONG day...
Quick MS-PAINT job
Wait wait wait wait. Wait... Wait...
I was right, huh? 😛
Quick MS-PAINT job
I was right, huh? 😛
There's a first time for everything. 😀
How can I remove all the lint from my electric dryer vent?
My dryer vents out the back, up a duct to the roof. On the roof the vent is capped and the cap is riveted to the duct. I was able to reach underneath the cap, and remove the lint nearby, but I want to be sure all the lint is removed from the duct. Or, what type of repair-person would I call to have it cleaned if I have to?
Also, is it fairly easy to make your own "solar screens" for windows? The type of screens that prevent light from coming in from my west-facing windows. I've seen all the supplies at my local store, just want to know the degree of difficulty.
You could call a furnace vent cleaning company or just buy a chimeny sweep brush, use a shop vac. to draw the dust out as you sweep.
If you want the screens to look decent you probably have to have a skill degree of 7+
