blackllotus
Even if the military has made advances with the system, they probably wouldn't tell anybody until they had to use them. Its possible that this is the case here, however I find it unlikely.
Originally posted by: CaptnKirk
You've got about the same chance as that of derailing a locomotive with a ball-peen hammer.
Which is why best chance was for a extreme high power Laser Satellite system (AKA Star Wars) that never got off the ground because we are too busy lining personal pockets with big Oil money and phoney wars.
Plasma based Laser FTWOriginally posted by: CaptnKirk
Gas Dynamic Lasers that are capable of striking from orbit are big, heavy, slow to position to fire, leak their fuels,
and would be difficult if not impossible to maintain.
Geo-sync orbitys if positioned to park over a designated target area are outside the envelope of access for the Shuttle.
Beam attenuation would render the method usless once we probe into the atmoshpers, so all targeting would have to be done in space.
Even the AirBorne Laser as carried by a 747 class vehicle, would have severly restricted capabilities for deployment.
They can't fly high enough, are not inherently a stable platform for target aquisition from, and can't fly
into target area countries without risk of being attacked themselves.
Shoot it down? Seriously, we can't.
We attempt to do so will expose how inept our multi-million dollar Missle Defense System really is.
We could barely hit pre-arranged staged flights to test the development of the phases of milestones in process.
No real need to expose a weakness, let them stay guessing - can they or can't they.
Originally posted by: ntdz
Personally, I think all those reports of us not being able to hit the missles are a publicity stunt as to not let our enemies know we have a working ABM shield.
Originally posted by: MadRat
So, kirk, could SM-3 take one down?
Raytheon SM-3
This is a generational improvement on the Patriots from over a decade ago.
Like the enemies who matter (Russia, China, etc.) don't track and observe our tests. They know what's going on much better than we (the genral public) do.
Originally posted by: aurareturn
If you, a normal US citizen knows that our anti-missle system sucks, then what makes you think that their government doesn't know? What's there to hide even when you know?
These new-fangled systems can only kill with direct or near-direct hits, and can only use blast or impact to kill. Youi want a real deterent? Go back twenty years...
Originally posted by: Nyati13
If NK does launch that test missile, I seriously doubt that it would be aimed towards the US. It would likely be angled SouthWest into the middle of the Pacific. That trajectory would take it so far away from the Anti-Missile system we have in Alaska and California, that we couldn't shoot it down even if the ABM system did work.
Which it doesn't so that's a moot point anyway.
Haven't you been watching Fox News?! Their animated graphics CLEARLY show a 3-stage NK missile blowing up San Francisco.
Originally posted by: Future Shock
In all of this discussion of ABMs, there is nothing seriously being debated about the old Nike-Zeus system, which most probably worked: you want to kill a nuke, use a nuke. Don't play around with this mamby-pamby ultra-precision guidance stuff, throw up a few Nike-Zeus interceptor missles with nuclear warheads, and saturate the incoming warheads with neutrons and blast effect that will either destroy them outright, scramble their detonation systems, or saturate their primaries so they are rendered inoperative.
Well CNN shows it hitting Alaska!!! Just proves that the news media don't have a clue
A) What makes you think that I am a 'normal' US citizen ?
The only way to take out this missle, other than a bombing of the vehicle on it's launch pad, with our present technology status,
would to be to know within a roughly 50 mile radius of what the target area is, and be there with a battery of anti-missle systems,
and launch a cloud of interceptors for it to fly through during it's decent to target phase of re-entry.
Could we get lucky & get the collision that would knock it off course? Maybe, but that chance is minimal.
Realistically - if this incoming weapon system was successfully intercepted, it might fail to arm and detonate....
....splattering radioactive debris (If it were to be armed with a crude thermonuclear warhead)
all over the target area footprint - a pattern of hundreds of square miles of area, either land or sea.
However should it have been successfully armed it could detonate on impact, or simply be deflected off target by a few miles from it's intended target site.
High altitude detonation is the best scenario that we can hope for if the weapon system is armed.
Russia built 50 Megaton warheads, knowing that a miss of 100 miles with a warhead that large was a moot point.
Our Nuclear weapons throw 150 Kiloton warheads - a fraction of the power of the soviet design,
but nominal point of impact for our targeting is 90 meters or less at ground zero CEP.
We also 'Cap it off' with an aerial burst, which is positioned 1 mile above the ground blast
which 'Pancakes' the ground detonation,
and forces it to spread out sideways accross the ground, effectivily increasing the magnitue of the blast by 100 times.
Originally posted by: spelletrader
The largest yield warhead they ever put on missiles was 550 kiloton, and we had equivalents.
This is incorrect. Both sides fielded ICBMs mouting multi-megaton nuclear warheads at one time or another.
The Titan II comes to mind for the US that carried the W-53 in a Mk.6 RV yielding about 9MT.
Currently the US missile force use the W-87 warhead yielding 300KT (mounted in singles on many MMIIIs after the Peacekeepers were decomissioned), the W-78 warhead yielding about 350KT (also on the MMMIIIs), and the W-76/W-88 (100KT and 450KT respectively) combo in the Trident D5s that are in the Ohios.
Blah, Blah Blah
So you boast of ICBM RV accuracy but cannot fathom that we can create ICBM interceptors that can be even more accurate than systems that were designed years ago? /boggle
We can and will shoot down anything North Korea tries to put up in the air if we feel it is a true threat.
Even today our intercept record is absymal, considering the controls to these staged test events.
You don't seem to even concerned about the aerial dispersal of plutonium over the planet's atmoshpere and it's efects.
As far a NK goes - do you really think they are the technological equivalent of us in rocket science?
They'll be lucky if it doesn't blow up in their face, nuking themselves in the process.
They don't really appear to be as advanced as our Vanguard was in 1958.
Nice to see that the MX is being retrofitted to launch satellites, as was the final fate of the Titans.
Scott
