Myth TV
ultimatebob
25,134
2,450
Originally posted by: thedarkwolf
I'm too stupid to be able to set it up.
They have bootable LiveCD's that you can try, but they'll only work if you have supported video hardware.
AnonymouseUser
9,943
107
Originally posted by: newb111
I gave it a try, but I must be doing something wrong because the live TV doesn't look very good.
Specs:
Athlon 1800+
512mb ram
200gb HDD
pvr-150
tnt2 ultra video card (hooked up to TV via VGA cable)
Any advice?
Have you compared the results to any online reviews of the PVR-150? None of the cards will look as well as regular TV since the image you are seeing is compressed, but it should look decent enough.
Reel
4,484
Specs:
Athlon 1800+
512mb ram
200gb HDD
pvr-150
Any advice?
I am actually going to approach it from the other side. You connect to TV via a VGA cable. Are you deinterlacing the image? Try Bob if not. Try downloading some known video file from a random web site and viewing it on another PC then view it with mplayer or xine or mythvideo on your TV. Try to narrow down what component is causing the quality loss.
