Originally posted by: TehMac
OH FOR FUCKS SAKE. I just realize I posted the same picture three times.
Well I updated, but yeah, this confirms Apex is right.
I tried too hard yesterday to find differences on the pictures with no luck... now I know the reason.
Yeah, sorry about that. I forgot to check, it was late at night. 🙁
Usually someone calls me out on it, so no one had and I didn't know.
But yeah, I guess it is a Russoin Q1. Brilliant. And Apex has a Noble? Dayum.
Originally posted by: KentState
How about this one? I saw it rolling by me on the freeway today.
http://i27.photobucket.com/alb...hio/cp1_0614091426.jpg
http://i27.photobucket.com/alb...hio/cp1_0614091427.jpg
http://i27.photobucket.com/alb...hio/cp1_0614091429.jpg
That one's easy - Bugatti Veyron.
Viper GTS
Viper GTS
wtf, how do you not know about the Veyron! if I saw that thing next to me Ill follow it lol.
Thanks Apex, that looks 100% spot on. For all you guys saying Noble M400, that was sort of correct because Rossoin purchased Noble and the rights to the M400, which the Q1 is based on heavily. But, while the M400 is designed as a race car, the Q1 is more sports car oriented with more luxuries. But still, with that kind of speed times...they did a tremendous job.
It would really suck to run into a Veyron while gawking. I carry higher insurance limits than most people but my $500K CSL policy would barely make a dent in the cost of a new Veyron.
Viper GTS
Originally posted by: Apex
Side note: Even with just 450hp, there's enough power to spin the tires in 3rd gear and probably chirp going into 4th, despite the mid-engined layout. These cars are about as light as a stripped Mini Cooper. If you want more fun though, get yours up to around 600hp and you can spin 5th gear, even with DOT-R tires. 🙂
Would you get 600hp with a chip?
Getting above that reliably on the swill that passes for gasoline here in CA requires upgraded pump, injectors, exhaust.
Getting up to the 600 mark, it really helps to have an upgraded intercooler and slightly bigger turbos (ie. GT28RS vs GT28R).
Originally posted by: Safeway
Apex and ViperGTS, what do y'all drive -- seem to know quite a bit about this Rossion.
Originally posted by: Gillbot
$4400 is cheap? I'd hate to see what you consider expensive. Hell, for my car I can get a built replacement to handle nearly 1000HP for about $3500.
Yeah, $4400 is not an expensive engine at all for a $100k vehicle that, stock, runs 0-60 in 3.3 sec and corners at >1.14g. Especially when you consider it's reasonably built (Wiseco forged pistons, Scat H-beam rods, forged crank, ARP bolts, piston squirters, balanced, blueprinted, etc).
The M5/M6 engine is $29k for just a rebuilt short block. Brand new, it's over $40k.
A new LS2 crate is about $5-6k, and that's with cast parts.
I just looked up the Rossion Q1 -- I now know what supercar I will own first.
I just built a new 355 for my 63 vette, the SBC has to be nearly the cheapest platform out there, and my build is pushing $4k without any really exotic/fancy parts, straight up blueprint engine with dart heads.
A zz4 crate motor, at around 350hp runs just under $5k, the ZZ383 at 425hp quickly gets over 6k.
I'd call $4400 cheap too
