My Z-5500s are popping randomly
Vin0134
102
I got the Logitech Z-5500s for Christmas and they are great. They worked fine at home(no popping) but now that I moved them into my dorm the front left, front right, and center speakers pop randomly every 5 minutes or so(as far as I can tell the rears are fine). This happens whether sound is coming out or not. I'm pretty sure I installed the speakers correctly, the correct sound is coming from the correct speaker. My only thought is that the wires for my computer, monitor, xbox, and the speakers are all cluttered behind my desk. Does the close wire proximity cause this problem?
alcoholbob
6,380
448
I've experienced speaker popping before, and its usually because I 1) have too many background programs running or 2) spyware. Check for both.
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,204
45
You could be getting some interference from the other cables.
Is this hooked up to the same computer and same soundcard?
If you have the speaker on but not connected to the computer, do they still make the popping sound?
Vin0134
102
I may have one or two background programs running but nothing is different from when the speakers worked fine at home.
Yes
Haven't tried this but I will.
YOyoYOhowsDAjello
Aug 6, 2001
31,204
45
Originally posted by: OnEMoReTrY
Is this popping happening during while watching a DVD through Cyberlink DVD program
"This happens whether sound is coming out or not."
I took that as it happens all the time.
InlineFour
Banned
Nov 1, 2005
3,194
i had the same problem with my z5500. whenver i light switch was turned on or off, the speakers would make a popping noise. i'm assuming it has something to do with the power supply in the subwoofer.
Vin0134
102
Even when not plugged into my computer, the speakers are still popping. This is happening when no sound is being produced as well. Cable interfernece then? What do I do to fix that?
YOyoYOhowsDAjello
Aug 6, 2001
31,204
45
Take the speakers into another room and a different outlet away from all cords and interference.
If they still pop when on, then something's wrong with them.
InlineFour
Banned
Nov 1, 2005
3,194
the audio cables plugged into your computer is not causing the interference. it's the power cable.
BWMerlin
70
My guess would be mobile phone interference. I have seen this many times where the speakers act funny for a while as people receive text messages (quite handy sometimes as an early warning when you are reviving a text). It doesn?t have to be a phone in your room to set this off (I also live on university halls housing). My speakers (hi-fi stereo) don?t do this because I believe they are shielded as apposed to other speakers. You could try replacing some of the cables with shielded cables and see if that helps other wise just live with it (not like you can ban everyone from using there mobile phones so your speakers don?t act up).
mehmetmunur
201
I agree with the last post. I have the same speakers, and hear popping noise when the dish washer behind the tv, in the kitchen starts working. No poppong when it is not working.
CVSiN
9,289
check your power cord make sure its plugged in all the way..
check all connections something sounds like its touching
nboy22
3,304
Here's what happens with mine: they ONLY pop when a light switch is turned on that's near my room... I can usually tell when someone enters the kitchen because I'll hear the pop.... Can you time the pops and see if the intervals are in a type of pattern? It maybe the circuits in your dorm building.. every time someone turns on a decently power consuming device, it pops... That's just an idea from my experience.
Unkno
1,659
well, i have the X-530, not the same as the Z5500s but these are its lower ends and from the same company....i too had the popping noise before, i was using an NF4 motherboard with the integrated realtek sound.....my problem was fixed by upgrading to the lastest audio drivers from realtek...seems the speakers/mobo is really picky on what drivers you use.
but, since you said there were still popping noises when not connected to the computer, it's most likely your power cord not being shielded.......would a ups work as a power protector thing?
terentenet
387
No guys, listen to me. It's not the drivers/plug not plugged all the way/wires touching. Test this. Let the computer off, keep the speakers powered. I bet you'll still hear the popping. It's the power lines. Use a filter on your speakers. That will do the trick. It's also cheap.
Thanks
