Originally posted by: meltdown75
ice cubes, stat
Originally posted by: FoBoT
tap water has no cooler, it basically reflects the current ground temperature
if it has been hot for many days, the ground temp may be higher than normal, hence non-"cold" tap water
fill up a pitcher and put it into the fridge
ice cubes, stat
Yes, there is this little known invention called ice cubes.
I'd suggest you google it and do more research on them.
ice cubes, stat
the HHGTG has something to say about ice, i'll go dig up the link
found it: here ya go
Originally posted by: akubi
someone's pissing in your water supply
Originally posted by: dullard
I hate it when I'm on vacation and have to brush my teeth with lukewarm water. And no, I'm not going down the hotel hall to get ice to brush my teeth.
