Ruroni
First, thanks for the reply. Okay I'm done with all th modifications to settings... I still can't get a steady 125FPS, even at 800x600 it still fluctuates deom 90-125fps in Q3A...Originally posted by: Mem
V-sync is in the ATi control panel,3D tab then click custom button you`ll see it(for 3.8 drivers).
Did you disable trueform and and install the latest Hyperion VIA 4.49 drivers?
Some Bios tweaks worth a shot,disable all video ram cacheable,disable system bios cacheable,disable all video shadowing,disable fastwrites,and it`s worth playing with the AGP aperture size,with your total ram size you can play with the 64mb,128mb,256mb AGP size and see which gives the best performance.
Yes I have the latest drivers for every component in mycomputer, available...
