If they don't cover the thing (which would blow me away), I'd ghost ride it right through the front doors of the damn dealership.
I was there yesterday, they still hadnt finished fully checking everything, but he mentioned something about a broken pulley.
They said something happened with the pulley for the idler - it broke or came loose, and it ripped the timing belt - not completely ripped it, but has multiple tears. So they'll probably replace the timing belt and they're still checking to see/check for additional damage.
+1 ^
interference motor + screwed up timing belt = gimme new motor
I hope they have given you a loaner. I am in the market for a new car but these kind of problems with Subaru (known for blowing head gaskets) make me hesitate to consider them.
Any new update on this?
I talked to them yesterday, said they got a new timing belt. Before they install it, I asked them if they were going to check the engine and they said they would check the valves to make sure they arent bent.
The dealer said they are going to return the car next Tuesday. I've been getting tired of all this delay and decided to call Subaru of America because I think the dealer is milking the job and jerking me around a bit. Lets see what happens when I rattle their cage a bit.
They're trying to figure out how to handle bent valves. IMO if it "tore" enough to make the engine stop and coolant blow it then it's not just a slightly torn timing belt. It probably bumped a couple of teeth at least
Also note that this is a prime example of why you DON'T keep driving a car that's acting up. You turn a $500 timing belt replacement problem into a $5000 new engine problem.
