My son just told me a pun: Suprised me because he came up with it - quite good for 10 imho. . .
Wag
8,288
8
What kind of wine does a Jewish Jamacian drink?
Monischewitz...
Platypus
31,046
321
Server Error in '/' Application.
Could not continue scan with NOLOCK due to data movement.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Data.SqlClient.SqlException: Could not continue scan with NOLOCK due to data movement.
Source Error:
The source code that generated this unhandled exception can only be shown when compiled in debug mode. To enable this, please follow one of the below steps, then request the URL:
1. Add a "Debug=true" directive at the top of the file that generated the error. Example:
<%@ Page Language="C#" Debug="true" %>
or:
2) Add the following section to the configuration file of your application:
<configuration>
<system.web>
<compilation debug="true"/>
</system.web>
</configuration>
Note that this second technique will cause all files within a given application to be compiled in debug mode. The first technique will cause only that particular file to be compiled in debug mode.
Important: Running applications in debug mode does incur a memory/performance overhead. You should make sure that an application has debugging disabled before deploying into production scenario.
Stack Trace:
[SqlException: Could not continue scan with NOLOCK due to data movement.]
System.Data.SqlClient.SqlDataReader.Read() +176
System.Data.Common.DbDataAdapter.FillLoadDataRow(SchemaMapping mapping) +175
System.Data.Common.DbDataAdapter.FillFromReader(Object data, String srcTable, IDataReader dataReader, Int32 startRecord, Int32 maxRecords, DataColumn parentChapterColumn, Object parentChapterValue) +260
System.Data.Common.DbDataAdapter.Fill(DataSet dataSet, String srcTable, IDataReader dataReader, Int32 startRecord, Int32 maxRecords) +129
System.Data.Common.DbDataAdapter.FillFromCommand(Object data, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior) +304
System.Data.Common.DbDataAdapter.Fill(DataSet dataSet, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior) +77
System.Data.Common.DbDataAdapter.Fill(DataSet dataSet, String srcTable) +36
FuseTalk.database.RunQuery(String QueryName) +152
FuseTalk.API.GetThreads(Int32 CategoryID, DateTime DateAgo, Int32 MaxRows, Int32 UserID, Int32 ForumID, Boolean PrivateTopic) +639
ASP.categories_ascx.__Render__control1(HtmlTextWriter __output, Control parameterContainer) +2080
System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +27
System.Web.UI.Control.Render(HtmlTextWriter writer) +7
System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +243
System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +72
System.Web.UI.Page.ProcessRequestMain() +1926
Version Information: Microsoft .NET Framework Version:1.1.4322.2032; ASP.NET Version:1.1.4322.2032
