- May 6, 2020
- 717
- 1,817
- 136
In anticipation of the upcoming zen 3 release and Zen 2 XT refresh, I decided to sell my 3900x now before resale plummets in the near future. After hearing it mentioned that the more recent 3600's were clocking much higher than older silicon I decided to go ahead and pick up an R5 3600 last week as a place holder. The 3600 CPU was manufactured the 7th week of 2020. I have a full custom loop so I figured I'd OC the snot out of it and share what I found.
PCPartPicker Part List
Yes, I fully realize this a ridiculous build to pair with a 3600. Still I think impressive results could be had with a good mid-range air cooler and B series board.
I ended up achieving stability with CCX0 @ 4.55 Ghz and CCX1 @4.5 Ghz. This took around 1.28V as reported by HWI64 on SVI2 under heavy load. I'm running low (level 2) LLC so voltage is set to a fixed value in BIOS of 1.3125. I was able to pass multiple runs of Intel Burn Test Standard, over an hour of Prime 95 with AVX disabled, and a full 8 hour Real Bench stress test. As I found with my 3900x the temps get toasty in a hurry when you start pushing the clocks. Even with fairly sane voltage. Here are some results to check out:
EDIT:
I have updated thermal data after playing around with my fan curve. An extra 500 RPM dropped water temps by 5c after reaching steady state. I'm including a data with %100 fan speed for reference. While I originally had the fan profile set for absolute silence I think the new data is probably more realistic. While the fans are now audible under heavy load they are what I would consider completely tolerable.
EDIT:
