My Max Ram setting
ok I have a Abit Ic7-MAX3 and a P4 2.4C @ 2.8Ghz. I have my FSB set to 230(quadpumped) and my Ram is at a ratio of 5:4. Making them run about 184Mhz. with a Latency of 3-8-4-4. (RAM is 2x256 TwinX-PC3700) Their default latency is 3-4-4-8. The specs from the site says they can run up to 233Mhz. So my question is.
Can I set my RAM ratio to 1:1 without any problems and keep the latency. Or should I lower the latency and leave it at a 5:4 Ratio? Which would give a bigger gain? Currently have 2.8v running to the RAM. Should I change that?
Any suggestions?
On the other hand should I leave at a 5:4 ratio and up the FSB to 240 maybe 250? Cooling shouldnt be a problem since im gonna get it fixed soon enough. But right now Im running 44 IDLE CPU temp..
Please any suggestions or tips are appreciated. Thank You.
yeah dude...
run it at 1:1 at 233 and 3-4-4-8
though i think it may be able to run it more tightly but i dunno.. go for it though!
