The FM frame rails are worth the effort on a first go-around. One of the best mods I've made to mine chassis-wise. I've also got a FM stage 2 suspension, it rides awesome and does well in autox.
I figured that I'd do those at the same time as the transmission swap. Might I ask if the trans, drive shaft, of PPF were in your way at all during the install? Also, did you 'just' get the rails or did you get the rails with the butterfly brace? I'm thinking of getting the rails and then if I use the car for autox, maybe adding the butterfly brace later. It's only like $20 more if you buy the brace and rails separate and I'd like to get an idea of what the brace will be blocking (exhaust, trans, etc...) before I buy one.
Ummm... Hey, OP, should I start another thread? Or are you still cool with going OT?
