My laser printer causes my smoke detector to chirp
Status
Not open for further replies.
alfa147x
29,307
When I print from my laser printer it causes my smoke detector to chirp but does my breaker not trip?
I have the HL-2270DW
LTC8K6
28,520
1,575
It's likely a voltage drop causing the detector to chirp. Your voltage is dropping momentarily under the load of the printer kicking on, and your detector is very sensitive to that. Your circuit breaker couldn't care less.
alfa147x
29,307
Thanks for the help. Would this cause any damage to the HT equipment I have?
Tim_Derr
406
1,181
Yes, but in most states a hardwired smoke detectors have do be on their own circuit.
LTC8K6
28,520
1,575
That probably wasn't in effect when older buildings were built, and it may not apply to hardwired detectors with a battery backup.
BladeVenom
13,365
16
Toner gets into the air. There was some medical studies on it, and I don't believe it was good for your lungs.
Status
