My just inserted Tbird...
Hei! Calm down!
I said 133x10 not 13x100...
I'm running 1333, which is 133 x 10.
Do you get it?
Default multi for 1.4 is 10.5, i'm running 10.
Ok?
No offense, but he said in his second post that he is running it @ 10X133 now for 1333mhz. So he is already running @ 133 FSB. He is not running @ 13 x 100 and trying to set to 133mhz. I understand what you are trying to say, but I think by reading his posts, that is not what his problem is. Plus he says it post and gets into Windows before it crashes, he wouldn't get that far @ 13 x 133...🙂
D'oh - I could have sworn I read 100x13 - my bad.
But anyway, it was a good solution to a problem many people seem to have. 🙂
Hei!
Finally i'm running @ 1400!!!
I tried the trick with 2 psu, but it freezed as usually 🙁
So i tried disabling Enhance Cpu Performance and Fast Cpu command Decode.
Without these options enabled, it's running fine at 1400...
What do you think?
<< Hei!
What do you think?
It works?
Smile and go play some counterstrike 😉
How does AMD do tests????😕😕😕
My cpu won't run a 1.75v!
Now i'm 1400@1.85 with everything set for maximum performance...
I think i can go down to 1.8... or maybe i can try 1.75, but i don't believe the tbird would accepst such a low voltage...
Problems and problems...
I found that @ 1400 my USB ADSL modem don't run!
It simply shuts down, and don't reactivate until the pc is resetted.
This doesn't happen @ 1200 (100)...
Any clues?
