Discussion My IPad Air 2 ...should I replace?
Geekbabe
Moderator Emeritus<br>Elite Member
My iPad Air 2 gets heavy use & I was wondering if I should replace it? The new Airs look tempting but so do the new iMacs. My current computer is a 2014 MacBook Pro & it’s starting to get a bit long in the tooth
It's actually on sale for $559 at Amazon right now (in green, anyway)! Not quite the discount you might hope for, but probably worth it unless you really need to save $20.
That was clearly in my post yesterday lol.
Anyway, my unstated point was that the iPad (7th gen) is a great value unless you really want the iPad Air. Usually around BF, the 32GB iPad is as low as $230 and the 128GB upgrade is as low as $330.
screen is gorgeous the extra bit of real estate makes a huge difference! Everything is fast, transitions are buttery smooth ... I am so thrilled with this🙂
