Sky OC was supposed to turn off hyperthreading,is HT still working when you OC your i3? If so please tell us/me the mobo and bios version.Sorry, not sure i understand the question?
I used SKY OC (a BCLK OC) to overclock the locked processor.
Wow,that's awesome thanks, if this thing will be able to oc the HT KL pentium it will be a killer deal.Asrock Z170 Pro4s using the following BIOS: http://overclocking.guide/download/asrock-z170-pro4s-non-k-oc-bios/
HT wasn't impacted - all 4 logical cores worked fine.
Maybe it's just a case of adding cpu id's to the old bios'es'sAs far as BCLK OCing a KBL Pentium with HT, I doubt it. You need the newest BIOS to run KBL, but the newer BIOSes kill off the SKY OC. (So I've heard.)
http://www.tomshardware.com/news/in...19.html?_ga=1.125112906.1314846558.1400174370
Looks like the board was the problem.
Considering the 5GHz 6700K hype that did not pan out (majority of samples, including mine, cannot break 4.6GHz fully stable) I will wait for a larger sample size of 7700K overclocks + Zen 8C/16T performance before considering my next CPU upgrade.
As of 10/11/16, the top 95% of tested 6700Ks were able to hit 4.6GHz or greater.
So you think 50c with a 5.0Ghz overclock is a high temp?? Heck I would be more then happy with those temps.Specially with air cooling cause upgrading to water the temp will only get better!! Could you try lowering the volts with the 5.0Ghz overclock? I would like to see what is needed for a stable overclock for running 24/7.
Edit..
Just seen your new post, those temps gotta be wrong. There is no way your hitting 89c without melting something.Also your volts are showing 1.36 volts I thought you were running it at 1.40v??
Not to be greedy or anything but could you check on the igpu,I know it's low priority for most people but it would be interesting to know if there is a change in EU numbers/clocks or if the en/decoding is hybrid or actually almost no cpu cost.
No more like what mikk says,if it has more eu/shaders then sky or if they have higher clocks and stuff like that.Do you mean has overclocking disabled some EUs? He has a K chip, nothing gets disabled when you overclock.
Or are you talking about his i3?
Notebook Check found HD620 to be 20-30% better than HD520 at the same shader count and clocks.There is no difference in shader count, it is exactly the same as Skylake. The only difference is in the fixed function and display unit. GPU clock is unknown, I would guess it is unchanged as well.
