Essence_of_War
- Feb 21, 2013
- 2,650
- 4
- 81
I am judging by the time it takes to encrypt a 4TB hard drive
AES took over 7 hours
Twofish cascaded with Sepent took 7 hours but seemed to finish first.
These were tested on 7200RPM drives NAS drives. I did time it. they said 6 hours but took 7 both of them.
Ok. And if you do a bit of math, 4TB at 7 hrs ~130-140 MB/s, which happens to be just aobut the maximum speed you can write data to a 4TB hard drive.
The reason you don't see any difference between AES and Twofish is that
1) You were IO limited - both Twofish and AES were fast enough to saturate your bandwidth to disk.
2) You didn't monitor CPU usage - if you had, you would have likely seen your CPU idling under AES and fully loading a core while doing Twofish.
