imported_Asteriks
First of all, many thanks 2 all of you for your posts, which have been of the greatest help, from choosing hardware to ocing.
My specs:
3200+ Winchester Zalman 7700-cu
MSI Neo4 Platinum SLI
1GB Crosair Twinx1024-3200xlpro
BFG 6800gt (oc 400x1100 couldn't get more but didn't try hard. went back till oc cpu)
120GB Seagate Baracuda SATA
Audigy2 zs
DVD-ROM
DVD+-R/+-RW DL
Enermax Whisper II 2.0 SLI 535W
Lian-Li PC7 Plus w/Vantec Stelth 80mm on top
Kinyo KY-100 5.1 headphones
Hyundai L90D+
OC@ 235x10 HT4x 1.45V+3.3%
1:1 2.5-3-3-7 1T 2.75V
Prime95 OK for 20h 47*C under load
agresive timings off
can't remember of altering anything else
This is how I got there:
220x10 @ 1.45+9.9% everything else the same
Prime95 OK
240x10
Prime95 long OK
Short NO GO
Runs 3dMark05 good
Doom3 timedemo good
245x10
same
250x10
reboot
235x10
Prime95 OK
235x10 1.45V+3.3%
Prime95 OK for 20h
235x10 1.45V
reboot
240x10 1.45V+9.9% memory @2.85V
Prime95 no good
mem timings up and no good again
240x10 1.45V+9.9% memory @166 @2.85V
Prime95 no good (memory shouldn't be the problem here)
245x10 1.45V+9.9% memory @166 @2.85V (just in the case that 240 is a bad luck)
Prime95 no good
238x10
Prime95 no good
235x10 1.45V+3.3% memory @166 @2.75V
Prime95 good. Anyway, with 2-2-2-5 performance in other tests not as good as @200 so I
gave up
235x10 1.45V+3.3% memory @180 @2.85V
Prime95 no good 2-2-2-5 performance in other tests not as good as @200
gave up
Back to
235x10 1.45V+3.3% memory @200 @2.75 2.5-3-3-7 1T
I am out of ideas what else to try.
Please, help me with any suggestions. What else should I try to get above 2350Mhz.
Also, if I am stuck here, what should I do to fine tune it from this point on. If I try to get memory timings down, in what order should I try (I tried geting CAS from 2.5 to 2 but it rebooted).
My specs:
Audigy2 zs
DVD-ROM
DVD+-R/+-RW DL
Hyundai L90D+
Prime95 OK
240x10
Prime95 long OK
Short NO GO
Runs 3dMark05 good
Doom3 timedemo good
245x10
same
250x10
reboot
235x10
Prime95 OK
235x10 1.45V+3.3%
Prime95 OK for 20h
235x10 1.45V
reboot
Prime95 no good
Prime95 no good
238x10
Prime95 no good
gave up
gave up
Back to
