Fritzo
- Jan 3, 2001
- 41,920
- 2,161
- 126
After my girlfriend was gone 9 days, I decided to make a change in my life. Currently I'm only consuming about 1200 calories a day.
That's a bit low for someone of your size. You should do 1600-1800 or you might feel sick/get fainting spells.
As for your rapid weight loss, you're losing a lot of water right now (you might notice that you're peeing a lot). The first two-three weeks of a strict diet you'll get great results:you'll lose 10, 20, even 30 pound very quickly. The bad side is, after your water retention is depleted, you'll start burning fat, at which point you'll only lose 1-3 lbs. a week. That's the point in which most people get frustrated and give up, because they're starving themselves and no longer getting quick results. You have to stick with it---it will be gradual (3-6 months), but you'll lose a good 20-40 lbs. over that time with your diet. When you start burning fat, that's when the payoff begins. Your body mass will start shrinking and people will start noticing
Here's some tips:
1) Eat several small meals/snacks a day instead of 2-3 large meals. If you eat 200 calories say...every 2-3 hours, your body will keep it's metabolism running at full speed and you'll lose weight faster. If your body feels like it's being starved, you'll enter "famine mode" and your metabolism will slow down...so you'll have to work harder to burn fat. This is why I suggested going to up 1600-1800 calories, as 1200 a day might not be enough.
2) You have to exercise. Muscle replaces fat, so producing more muscle mass will eat up your fat cells. Keep in mind that if you do weight training, your actual weight may stay the same (or actually increase!) due to the extra mussel tissue. This is why you need to do waistline measurements instead of using the scale as a guide. If your waistline shrinks, but you're not getting any lighter, that's not a bad thing
3) Do cardio workouts. These are great for losing weight because 1) You don't need to belong to a gym to do them 2) They can be done anywhere 3) It burns a ton of calories in a short time. Cardio workouts also increase your lung capacity and help remove plaque from around your heart ( the heart muscle replaces the fat surrounding it). Swimming is probably one of the most effective exercises because you use every muscle in your body...if you have a good swimming program, stick with it. Add some chest/arm/ab/glute weight training so you don't get all flabby when the weight comes off.
4) Once you get to a point where you're comfortable with your weight, raise your caloric intake to 2000-2400 (depending on how much exercise you're still doing). This will maintain your weight lever. And for God's sake...eat a cheeseburger or a steak once a week so you're not depriving yourself. You can still eat whatever you want, the key is you have to eat it in the right quantity. Giving yourself rewards will help you get into the mindset that you're not on a diet, you're living a healthy lifestyle.
Hope this info helps. I was really into physical fitness a couple of years back, but cut back after I had kids (I had the six pack going and everything...I just didn't have the 3 hours a day it took to maintain them anymore). Good luck to you.
