My eyeglasses' temple broke. Anyone know where I can get a replacement/how to fix?
Kishan
2,580
They are black Dolce & Gabbana with black plastic (somewhat flexible) temples, size 140. I will find out the exact model later. The right temple broke, but its not completely off. I gues electrical tape might do the trick. Anyone know of any replacement temples that I could find?
Thanks,
Kishan
EDIT: I bought them at Sterling Optical, and the rude man who answered the phone said they don't sell replacement temples. These seem similar to mine. Text
blakeatwork
4,113
Thanks,
Kishan
Temples?? You mean the spot where it connectes to the frame?? I don't think those are repairable.. at least my last frames that just broke weren't..
DeMeo
781
you're supposed to tape it back together.
Any kind of tape you like.
tami
11,588
krazy glue is an option
otherwise, new frames. when i broke my last pair, i got the same frame once again.
call another sterling optical. someone is bound to assist you.
Dec 28, 2001
11,391
I worked at Lenscrafters: we did not repair neither the "temples" nor the bridge.
Time for a new pair of glasses, buddy-o. :(
jmgonzalez
525
I broke the temple on my glasses and my optical provider had no problems ordering a new one for $30
Bootprint
9,847
They usually don't make a frame models for very long, I'm guessing probably 2 or 3 years supply. So you might be out of luck and will probably have to spring for a new frame and lenses.
Kishan
2,580
hey thanks for all the answers. I picked up some cartier rimless to use them as prescription sunglasses yesterday, but I think they may be too gaudy/expensive for regular use. Krazy glue is not a bad idea though.
To clarify, isn't the temple the part that is the stick? There are two temples, left and right, that fold up?
Google pic: temple
That should be a replacement part!
TerryMathews
If it's actually the temple that's broken, your eye doctor should be able to order a new one, assuming the frame isn't too old. If you broke the piece of the frame where the temple connects, it's new frame time.
Kishan
2,580
I figured so. The guy I spoke to at Sterling is a lazy moron!
Kishan
2,580
The frames should be around $300. Feels like a waste of money to me. Will try calling more Sterling's.
Thanks,
Kishan
nakedfrog
61,915
17,681
I've had various parts of my frames replaced a number of times... every part has been replaced at least twice, except the lenses. I just went back to the mall and asked to buy a replacement for the broken piece.
