mechBgon
k, that helps, because that sounds like something your Fortron 300W unit can handle (provided it's healthy). I can't tell from your photo what motherboard you have, aside from that it is probably an Intel-brand board with a model name that includes "D845PE___", maybe a D845PEBT2.Originally posted by: ZavrionX
http://www.freewebs.com/naeseion/cap_002.jpg
Black ;3
1) 1
2) 2
3) Radeon 9200 (I thinks)
4) Pentium4 2.53 GHz (I thinks <.< )
That's some help, because the Intel boards are going to all use the same pinout on their front-panel connector. http://pics.bbzzdd.com/users/mechBgon/INTEL_FRONT_PANEL_CONNECTOR.gif That should help you get your case wiring going. If the LEDs don't light up when they ought to, then just flip the plug 180° and plug it back onto the same pins.
One other thing I would like you to check: look at the ATX12V cable and confirm that you got it plugged into the mobo in the right orientation (the latch on the plug should line up with the catch on the receptacle).
