My computer reboots spontaneously...
I dont think it is heat! That almost sounds right for the ultra hot 1.4ghz Tbird! Its probaly PSU if not then your computer is haunted! BOO!
i'm pretty sure it's not the Power...400 is plenty.
-Ed
Installed the new HSF...lowered the temp to 45C....but it still reboots randomly....should i replace the memory?
-Ed
okay.. i had this problem with an ATI video card... did you just recently upgrade your driver? try remove all the video driver and clean install the driver.
my friend has a similar problem and it turned out that there was some dust collected in the memory slot.. he cleaned out his system and it's fine.
nope haven't just upgraded my driver...though I do have an ATI card though. I think i'm gonna go for the ram solution...and soon thereafter i might change m/b's. /=P
-Ed
I think its an ATI problem. i changed my memory form Samsung basic memory to Corsair XMM series memory.
and I still get reboots.
dammit...so i gotta get a new vid card? grrrrrrr....i wish i just knew what the dayam problem is /=P
-Ed
