Question My computer produces a crackling sound. What is the problem?
Hougy
I have a Sound Blaster Z and sometimes it produces a crackling sound or a little pause.
I always assumed the audio card had some kind of problem, but recently I tested the audio from the motherboard and it has the exact same problem. What could be the cause and how can I fix it?
The motherboard is a Asrock Z87M Extreme4 with a 4670k @stock
VirtualLarry
56,570
10,203
Tried turning your speaker off, then turning the volume knob all the way down and up again a few times, then turn it back on? Or use some contact cleaner on the speaker cable plugs / jacks.
Reactions: Hougy and RLGL
kschendel
292
230
When two different, reasonably independent sources produce the same symptom, it's a good bet that the problem is downstream. So: bad cable, bad or dirty connectors, bad or dirty volume control in whatever amp you're using (whether speaker builtin or outboard), etc.
Hougy
Thanks.
I only use headphones and I also has this issue with another pair.
Maybe the issue is that when I move the cable also moves and sometimes the jack moves in a way that causes noise? I will try fixating part of the cable.
Could it also be an issue with the PSU or with improper grounding?
mindless1
8,634
1,691
^ PSU would tend to cause slight background humming or static that varies with load, not crackling.
You definitely shouldn't let the headphone/other cable continually move and put changing pressure on the analog audio jack.
Reactions: Leeea
