My computer help thread
Rapid Fire
455
Originally posted by: Rapid Fire
Ok I am dont plugging the cases components into the motherboard but i have 3 cords left over one says "1394" on it another says + on it, and the last one says - on it, but the last two are sorta connected, so I was wondering do I need those last ones or not? I cant tellw hat theyre to because the wires are like hidden int he front of the case.
Rapid Fire
455
Ok I am done plugging the cases components into the motherboard but i have 3 cords left over one says "1394" on it another says + on it, and the last one says - on it, but the last two are sorta connected, so I was wondering do I need those last 3 ones or not? I cant tell what theyre to because the wires are like hidden in the front of the case.
Rapid Fire
455
Rapid Fire
455
ok, ill guess ill' move on to next question, what would be the difference if i got a amd athlon 64 3200 compared to a amd athlon 64 3400?
Rapid Fire
455
Ok, I have a few unanswered questions, and btw i appreciate everyones help on this:
1. I am done plugging the cases components into the motherboard but i have 3 cords left over one says "1394" on it, another says +(positive) on it, and the last one says - (negative) on it, and I was wondering what theyre for and if i need them or not, because i have no way of seeing what they go to because the wires dissapear into the front panel of the case.
2.what would be the difference if i got a amd athlon 64 3200 compared to a amd athlon 64 3400? (see my system specs on first page of this thread).
Rapid Fire
455
Rapid Fire
455
3.you know the audio wire that connects from your cd drive to the motherboard well i was wondering which side goes into the motherboard and which side goes into the cd drive, one side of the wire says "best", the other side is blank.
