- Mar 12, 2013
- 31
- 0
- 0
In my other first-timer thread, the first writers also issued complaints about the lack of inventive choices for smaller cases.
Case height has traditionally been Height Of Power-Supply Plus Height Of Motherboard. The LianLi A05 has an interesting alternative - shoving the power-supply up to the case's 'chin', beneath the limited drive-cage, giving the entire 'height' based on the motherboard's dimensions.
The Cube Cases are generally wrong (APEVIA, to name names!) because they load the motherboard onto the bottom 'deck' - and that always has the most access issues. Users need to plug in, pull out, tug, pull, push - the Cube Case Makers need to ALWAYS put the motherboard on top. Put the drives and power-supply onto the bottom area. Those can slide in and out using a single direction.
But Case Height can also be shortened by making the vertical cases wider. Make the cases 2 inches wider, and offset the drive cages 'above' the motherboard tray. That gives easy access to SATA and all other motherbaord connectors, and allows drives to be slid in and out without cable-connection interference.
I find the Small Case dimensions incredibly unimaginative, and all too similar. 14-15" height, 15-16" depth, 6-7" width. I think that covers about 99% of small towers. Why not 13 inch height, 17x9 inch depth-width to give plenty of distance between MB connectors and Drives. Make working on cases EASY!
