Jim Raynor
Dear forum members,
After reading alot of reviews on the main page of this site and some general browsing around I decided to make a topic here for a new build I've been planning to do. This site seems really professional so kudo's for all the hard work and imput. So let's start with the template.
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
I'm a multitasker and a gamer. What does the first thing mean? Well the following is not uncommon for me: MSN, Teamspeak, Winamp, Firefox 20 tabs, a game alt-tabbed, some documents with work.
I also like to play games, all games, I think that's the most important factor here.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
The budget is around 1k euro's. When asked I'll post the approximate prices of the products that will be recommended so you guys can get an idea of the budget. That's because it seems most of the visitors here are Americans. The budget may be stretched 20% ofcourse but I rather stay around the 1000.
3. What country YOU will be buying YOUR parts from.
Europe, so no new-egg D:.
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
I'm quite new to this pc building so I have no preference. Quality and warranty is where brands excell.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
I have keyboard, mouse, headset, old screen etc. I also have a spare dvd drive but those things won't break the bank anyway.
6. IF YOU have searched and/or read similar threads.
Yes I did, I've read ALOT in my spare time so I must have some basic knowledge.
7. IF YOU plan on overclocking or run the system at default speeds.
Overclocking within safe margins is an option but as I said I'm new to this.
8. What resolution YOU plan on gaming with.
I don't have a screen and that will be bought later, it will be a seperate decision after the rig is bought and put together. So the budget excludes the screen. It will probably be 1920 x 1200.
9. WHEN do you plan to build it?
Within 1/2 months, I'm a careful buyer so I rationalyse every decision before buying. Time is not an issue.
I've established a few shortlists but choices are ofcourse not limited to those. I'll start with the shortlists being general guidelines.
CASE
HAF 922
CM 690 II ADV
Lancool PC-K62
I tend to favor the HAF here.
PSU
Haven't done much research here but:
Antec TP 650/550
Any Corsair
I favor modular PSU but does it really matter?
PROCESSOR
Socket 1156 -> i5 750 or i7 860
Socket 1366 -> might be too expensive but i7 930
Socket AM3 -> 955 or 1050 (1090 might be too expensive)
I read about the Foxconn sockets and I'm quite afraid of that. I'm aware of the bandwith limitations of socket 1156 but crossfire doesn't seem to be an option within this budget. I tend to favor buying 1 card and upgrading 1 card instead of buying 1 card and upgrading with the same one in CF. I tend to favor the i5 or i7 860 here but as I said I dislike the messages about the Foxconn sockets.
MOTHERBOARD
Haven't done much research here. But:
Asus P7P55D (socket 1156)
GigabyteP55M-UD2 (same)
I read that Asus is a good manufacturer with quality products. USB 3 and Sata 6 seem to be unnecessary at this moment so it's not a factor to consider when choosing a mobo. Unless ofcourse you guys think it's important to buy one with those features.
RAM
OCZ Platinum Low Voltage OCZ3P1333LV4GK 4 gigs
HDD
Samsung Spinpoint F3 HD103SJ, 1TB
GRAPHICS
HD 5870 VAPOR-X or any 5850
MISC
Cooler Master Megaflow Red 200MM for the side fanslot of the HAF
Scythe Mugen processor cooler
For reference, this setup is around 1000 euro's.
Cooler Master HAF 922
Scythe Mugen 2 Rev. B
Intel Core i5 750
Antec TruePower TP-650
OCZ Platinum Low Voltage OCZ3P1333LV4GK1
Asus P7P55D
Sapphire Vapor-X HD5870 1GB GDDR5 PCI-E
I would really appreciate any thoughts about this pc build.
Thanks in advance!
Jim Raynor.
CASE
HAF 922
CM 690 II ADV
Lancool PC-K62
PSU
Antec TP 650/550
Any Corsair
PROCESSOR
MOTHERBOARD
RAM
HDD
GRAPHICS
MISC
Intel Core i5 750
Asus P7P55D
Thanks in advance!
Jim Raynor.
