- Jun 27, 2004
- 10,233
- 2
- 71
See chart for temp changes:
..........................................Stock GPU cooler & XP90.......Evercool Turbo2 & XP90...........VF900-Cu & Big Typhoon
GPU idle.....................................50c...........................................35c.............................................33c
GPU load....................................80c...........................................48c.............................................51c
CPU temp @ GPU load...............44c............................................37c.............................................33
Sys temp @ GPU load................37c............................................33c.............................................34c
Test done with my 7800GT at 485/1150. I ran rthdribl to stress the card for 15 minutes. Room temp is appx 22c.
Installation was very easy. Probably took 15 minutes from start to end, taking my time and being careful. Search google for more thorough reviews that cover the installation process. Link to installation and supported cards.
Noise is about the same or quieter. My other fans are louder than the stock 7800 fan, so I can't really tell a difference.
While I still don't know why my idle temps went from 35c to 46c with the Evercool Turbo2, it certainly wasn't the Turbo2 making all the noise.. it was the stupid northbridge chipset fan under my video card! I unplugged the chipset fan and now my computer is nice and silent and not running any hotter without the fan on.
I didn't figure out what the noise was until after I put the VF900 on, so I don't know how quiet overall my system would be with the Turbo2 installed, and I really don't care to put it back on. I'm getting idle GPU temps of 33c so far with the VF900. I'll test load temps in a minute.
