SSChevy2001
- Jul 9, 2008
- 774
- 0
- 0
My stock ref 4870 idles just fine at 550/200mhz @ 1.083v. The idle temp is around 43c @ 12% fan speed, which clearly shows that the power consumption has dropped a good deal.Originally posted by: Cookie Monster
Thing about the HD4870 and rather high idle power draw can be blamed on the use of GDDR5. With the initial implementation of GDDR5, i dont think AMD took advantage of the "power saving" features of the GDDR5. If you can successfully lower its memory frequencies (not sure about voltage), huge gains can be had for the idle power draw. The only problem is that the current boards in my knowledge, they lack the stability when reduced to a certain memory frequency threshold. So AMDs second implementation of this new memory module will probably be much more refined, i.e include these power saving techniques.
Why ATi didn't using higher load fan settings or better idle clocks is a mystery, but the 4870 has plenty of room to decrease the idle power consumption.
