Eug
OK, what size range then?Originally posted by: mAdD INDIAN
I didn't read the entire thread....but don't buy from the dealer!
Goto a local tireshop, there's one in Toronto called Steelecase Tires..and get Nokian Hakka2s. You don't have to get it in your tiresize, you can always change the sizes slightly as long as you get the approriate steel rim. I suggest getting winter tires on seperate steel wheels so that way its an easy swap when summer arises.
Any effect on the vehicle stability control or ABS?
