which IRST driver should i install? the IRST driver for 8x series or the IRST driver?
Neither. You're not using RAID so there's no point.
As for your question #1 above, it doesn't really matter. I would use both PCIe 6-pin connectors for a single cable because it keeps things neater.
As for boot speed, you need to distinguish between the amount of time spent by BIOS/UEFI and the amount of time spent loading Windows. Give us a breakdown of each time.
The speed of your SSD and CPU have nothing to do with the amount of time spent in the BIOS/UEFI, all of that time is spent initializing various controllers. Expensive boards with lots of fancy add-ons do boot more slowly becasue they have lots of extra "toys" (controllers) to initialize. The first thing to do is to turn off the full-screen BIOS/UEFI logo so that you can see what is actually going on. Once you see what is taking a long time, you then go into the BIOS and disable those controllers (assuming that you don't need them).
alright. how do i turn off bios / uefi logo?The first thing to do is to turn off the full-screen BIOS/UEFI logo
That one's on Intel: Rapid Storage Technology and Rapid Start Technology are both (I)RST.@cerb,
i misread it. it's Intel rapid start technology, and rapid start technology. haha.
HD. It's still not uncommon for them to have both headers, to handle people upgrading in older cases, but AC97 itself is old/dead.1)Theres ac97 and hd audio. Which one I shud plug in to the board audio plug?
Yes.Before buying the board I noticed that most nicer boards have some extra audio features like audio boost / purity sound / etc.
=> My question is,, if I plug in my speaker or headphone on the green plug in front of the case,, will the purity sound / audio boost / etc feature still works if I plug my headphone or speaker to the front of the case?
Well, that's a totally different issue. Being non-shielded non-twisted cable going through a PC case to the front panel, quality loss there is going to vary, but will have nothing to do with any effects.=> aka... will it have different sound quality than if I plug it directly to the motherboard green plug on the back of the case?
Varies. With PWM fans (4-pin), you can get splitters that allow control via motherboard headers, but power via the PSU directly. For non-PWM fans (3-pin), you either need a splitter for the motherboard header, or lose speed control through software.My Q is... if i add up 4 more fans, where should i plug it in? i think i noticed the board only have 2 or 3 SYSFAN plugs. Is this the situation where PSU molex cable for?
=> What's the difference between the fans plugged into the board SYSFAN plug directly and to molex connector? Can i still control the fan speed either way?
Probably not, if they're 3-pin, by software. You would need some other controller.=> Is there any way to make the fans move lesser than 50%?
Yes. Your board probably comes with software for it. Or, you can use software like Speedfan and Afterburner (though the software your video card came with was probably an old version of Afterburner).4) On [/FONT]my research while trying to understand which parts does what and choosing it I noticed reviews and general discussions of people talking about temperatures, VGA CPU and HDD. I notice[/SIZE] I can check it on BIOS. Is there a way / SW where can I check temperatures from within windows?
Those small ones with the raised key are floppy power cables. Floppies are basically dead, but some auxiliary devices, like fan controllers, and card readers, still use them, due to being small, and the connectors cheap and easy to implement.5) I have 2 cables from my PSU that I havent use yet, and I dont know what its for. Here are the picts.
No. SATA has its own power connector. Like the floppy power connectors, they're less used these days, but not quite dead. They used to be used for everything that needed extra power, like video cards, some P4 motherboards, drive controllers, phone cards, HDDs, ODDs...a) No.1 is the 2 SATA + 2 Molex Cable. Why do they combine SATA plug and Molex plug? Is it because the molex plug goes into the spiky parts of the HDD?
But what you do with the cable before the extension? And, you've got ribbon cables, which are not conducive to sleeving anyway.6) i read about sleving cables articles from google. i'm not going to DIY my cable myself since the tools is not easy to find here at my place. (at least i cant find it in my local walmart). i also find that my local retailers sell sleeved extension cables like this one here http://www.overclockers.co.uk/showproduct.php?prodid=CB-071-BX
Generally, interconnect cables are either male-male, or female-female, and extensions are male-female, to make a longer effective cable. In some directional standards, I'm sure they're the same, but 99% of the time, they're not.is extension cable different than normal cables?
You can grab the lower-left corner of the text input box, just under the vertical scrollbar, and make it bigger, to make editing easier.ps: i edit this on MS word... i apologies that the format becomes messy after i copy paste it to forum reply >_<
Maybe. You'll have to try it and see. In my PC, both sound atrocious, just like my last several motherboards.so... when i plug my headset... will the music sound quality differ if i plug on the green plug on the back of the board vs. the green plug on top of the case?
is it a big difference?
But, I'm not you. I plug them into my amp, which rests near my USB sound card (both soon to be replaced by a semi-DIY DAC+amp rig). There's 6 feet of USB cable, and maybe 4 feet of air, between my PC case and the analog audio.if you were me, where do you plug in your headphones to get the best possible sound quality for music?
If you're going to do that, yes, but it only adds one more set of contacts/losses, and it looks like you have plenty of room.2) regarding extension cables... if i buy those, can i go...
PSU >> Modular Cable PSU >> NZXT Extention Cable >> Motherboard
is that the right order?
loading windows from the PC is pretty fast, like 3-5 seconds, faster than the windows loading from my i5 ulv laptop.
loading the dragon gaming page on the PC (i guess this is the BIOS page?), on PC it takes 30-50 seconds, on my laptop, the brand logo takes 3 seconds-ish.
OK, so your slow boot time has nothing to do with the speed of any of your components, CPU, SSD, RAM, nothing. It's all about how long it takes you BIOS/UEFI to initialize all the toys.
Your motherboard manual is the best reference for this sort of question. What you want to disable is "Full Screen Logo Display", see page 3-14 of your manual.
oh, also forgot to mention
first is the i/o shield.
1) does that silver thing on the usb supposed to be like that or should i have bend the silver thing to make it inside the case?
The USB connector won't short anything, no, but it shouldn't work its way loose.
in your opinion... is this the bitfenix shinobi case 3.0 fault or the msi motherboard connector fault? or is that normal with the usb 3.0 connector design...? if its not normal what should i do abt it?
do you need a clearer picture of each to determine which one's at fault?
It's neither the "fault" of the case nor the motherboard. It's the fault of the person who installed the motherboard. And easily fixed if you pull it back out, maybe bend the flaps, and put it back in properly.
Half a world away, and not using MSI boards, I can't even speculate. It shouldn't be as tight as some other connectors, but it should be on there firmly enough that you could safely ship the PC. Make sure no pins are bent, though.in your opinion... is this the bitfenix shinobi case 3.0 fault or the msi motherboard connector fault? or is that normal with the usb 3.0 connector design...? if its not normal what should i do abt it?
would you guys mind explaining the traits of a slightly bent pins? my eyes couldnt tell the difference last night....
For every pin there should be a hole for it to go into. As long as it is straight enough to fit in the hole then you should be fine. Since you have got the plug all the way on down, all the pins are straight enough (unless they are bent fully flat).
My USB plugs are looser than the others also, but not so loose I think it would just fall out, and none of them click or clip in place. Maybe you got unlucky it's not tight, but it should still work.
If it fits, yes.does antenna from a wireless adapter and from wireless router interchangable? can i use my wireless router antenna and plug it on my PCI-e wireless adapter?
On the NIC? Not that I've ever seen. If it reflects back too much, try electrical tape over it.2) also is there a way to turn off the green epilectic-inducing status led-light off?
