jacktesterson
Did you make sure your HyperTransport stayed around 2000?
Never above 2000
Any suggestions to get a bigger o/c?
3.45ghz that's it??? shoot for 4 🙂
Came from Toronto area.
you should be able to hit 4ghz at 1.45v no problem. Just plug the numbers in and play.I got it up to 3.6 GHz.
can't wait to see how far I can take this chip. Any advice?
Very pleased as I was so close to buying a 960T or 1190T just to get a higher clockspeed.
I had ordered a FX-8120 but am not accepting delivery, Newegg is aware. Its not worth the cost over my O/C'd 1035T
I think I must have an engineering sample chip of some sort because I can't find anyone else with a 1035T that will unlock in certain situations/boards.
Then next up is to overclock the CPU-NB frequency to about 2.4-2.6ghz. After that you're set.
Maybe its an unlocked zosma? If thats possible...
I seem to have to add all kinds of juice after 3.6 to get higher.
Right now I'm running on Hour #3 of OCCT at 3.6GHz only on 1.375v and temps are well under where they need to be.....
I like he idea of staying at this voltage. I had to bump it up all the way to 1.46 just to get Windows to load at 3.8 GHz. 4.0 I'm sure would be more.
As in before....3.6 seems to be the magic area, which is a full 1 GHz overclock over the stock 2.6 GHz. I'm happy.
so I parted out my Office Desktop and kept parts to upgrade my TV gamer, which I use mostly anyways. A little overkill for HTPC and 768p Gaming, but I threw the chip back into the Gigabyte MICROATX 880g motherboard... and boom, full unlocked multi in the bios.
Set to 20x200, upped Voltage to 1.475, reboot. Bam.... 1035T @ 4.0GHz
Passed 4 hours of OCCT. When I get time I'll work on getting the voltage down.
Anyways, Click her to see CPU-Z Validation
Oddly enough, CPU-Z reads as a 1035T on the 990FX board, but as a 1030T on the 880G board.
