Mwave Mid Tower Case
$9.99 for me, make sure you REMOVE the power supply ... I eventually ordered one, having it shipped since work (and the drive keeps me busy). Mwave is down the street from my house...
so what do we need to fix the problem of the PCI cards not lining up properly? mobo risers? (where can i buy them)
be careful with this case. Looking at the internal shot I see its the exact setup as a cheap case I just bought from directron. If your motherboard extends out to the edge of the motherboard tray and mayb has pata connectors on the edge they will be blocked by any harddrive you try to mount in that position. Or if your motherboard has caps near the edge by the hard drives they will prevent mounting a hard drive. There is little to NO clearance. Out of all the hard drive positions you see I could only use the second from the bottom position due to caps/pata connectors/io connectors not allowing the hard drive to fit.
i have a similar mge case i got free ar from frys. VERY cheap contruction. metal is thinner than any ive ever seen- easily bent back and forth. this case looks the exact same on the inside and back.
it was ok for free- but not worth 20.00 shipped at all!
