Multicore Pi benchmark
Two issues with this multi-core Pi programs - Super-Pi correctly calculates the digits of Pi, multi-core Pi does not.
That was more or less my point (in response to your earlier reply)
The first "calculation" is always the same (practically speaking), regardless of clock settings... leaving it open, and calculating over and over again, it changes.
Even just looking through the posted images, the values are different, pick any 3 of them, they will all be different.
Here is an animation of 5 different posted images...
Values are all different.
P.S. I don't remember Photoshops animation stuff being this annoying before... lol that took WAY longer than it should have.
Well that's no good 🙁 (the lack of repeatability, not your image overlay, your sleuthing work itself is superb :thumbsup🙂
I think it's creating unique identifiers for later trojan infections, disguised in pseudo PI, that's why the application is so big for what little it does ... I kid... kinda...lol, although it would be an interesting way of encryption/keys.... calculate some sort of CRC based on the PC, find that value in PI, use the offset to identify the computer later... ok I'll shut up.
:hmm: hmmm, we did just download this thing from a romanian website, didn't we 😱
I could OC higher, but this is what I use my rig at, so heres what it got.
3930k @ 4.3
ram @ 1600
24s 855ms
Nice thinking dude .. ICU.
So my initial run was 45 seconds, second was 42 seconds and fastest was 40 seconds. That's quite a range of results.
AMD FX-8350, 2.2GHz NB, DDR3-1866 10-10-10-28-CR2, Win7x64 all updates applied. I shutdown and restarted the Multi-Core Pi application between each test.
FX-8350 2.0GHz 52s 908ms
FX-8350 2.5GHz 1m 4s 561ms
FX-8350 3.0GHz 55s 208ms
FX-8350 3.5GHz 1m 0s 885ms
FX-8350 4.0GHz 56s 652ms
FX-8350 4.3GHz 1m 4s 439ms
Intel i7-3770K, DDR3-1866 10-10-10-28-CR2, Win7x64 all updates applied. I shutdown and restarted the Multi-Core Pi application between each test.
i7-3770K 2.0GHz 1m 1s 670ms
i7-3770K 2.5GHz 49s 146ms
i7-3770K 3.0GHz 46s 471ms
i7-3770K 3.5GHz 39s 491ms
i7-3770K 4.0GHz 31s 209ms
All these results are suspect. The AMD results are clearly borked, but if you look at the clockspeed scaling for the Intel processor you will note they are borked as well.
Going from 2.5GHz to 3GHz reduced the process time by a mere 2.7seconds, but going from 3.5GHz to 4GHz reduced process time by nearly 8seconds? :hmm:
I feel confident to declare this benchmark is functioning as a chaotic number generator, both in terms of the computed values of Pi as well as in terms of the computed process time for the bench to run. Can it get more broken than that?
Ya those times don't make any sense, this so-called benchmark is useless!
Sorry for wasting you guys time, I won't even bother updating scores,
THREAD CLOSED! 😡
Those are some interesting results.
And the AMD ones are totally 😵 the uneven core speeds are slower than the even numbers regardless of higher clock speed!!
