I just installed my 3000 939pin & msi k8n neo2 plat. motherboard and ran into memory problems. I have 2 sticks of 512mb Corsair XMS3200 memory that will not run over 166mhz. I manually set it to 200mhz and still shows up as pc2700. I have messed with all of the timings with no luck as well. I even upgraded the 1.2 bios to 1.3 with no results. I am stuck and am getting very impatient because I can not find a single solution on the internet. I will appreciate ANY help.
Thank you,
Justin
Thank you,
Justin
