- Jul 16, 2001
- 442
- 0
- 0
I just upgraded my entire rig and I ended up with a conroe 2.66ghz 4mb intel 1333fsb processor, msi p6n platinum sli motherboard, and 4gb of patriot ddr2 800 ram matched sticks. But I have XP and Vista x64 ultimate loaded on seperate drives on the thing, in both OS's the usb keyboard and wireless mouse I have are extremely flakey. You will be typing for one minute and all of a sudden it will freeze a key on the screen and type it 15 times. It's not the same key or anything wrong with the keyboard, I tried it on a couple other computers. The wireless mouse is a Logitech G7 and it's brand new but one time when you load up windows the mouse will be fast at setting 2 and the next time it will be dog slow then speed up randomly at times by itself. I'm beginning to think the usb ports on this motherboard are bad because it does it in both operating systems. I was thinking about trying a pci card usb 2.0 to see if it was just the onboard motherboard usb ports but I don't have one readily available. I also have used a USB flashdrive on the thing but that didn't have any problems at all for the little amount I used it. Anyone heard of a problem like this or should I just RMA the thing from newegg since I just bought it a week ago?
